Thread: Imported tree present on every port
    Nov 2015
    Kingman AZ
    6
    Default Imported tree present on every port
    I imported a .sup for a tree and followed everything directing it to import it into my mega tree and it imported it to every port on my falcon 48. I can not do anything with the strings that are not part of the mega tree. I have tried inserting effects into the other strings and ports and it still only plays the sequence for the megatree. I have imported and nothing. Any suggestions?
    4,786
    Default Re: Imported tree present on every port
    Imported on what, from where, what are you modifying? There is not much to go on here.
    1,713
    I would assume since you imported a .sup, you are probably using xLights? What does your controller configuration look like. What does your model look like? How many models did you setup? What channels are you using for the models not in in your mega tree?
