Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: miniTree build suggestions wanted
    Ontario, Canada
    2,195
    Default miniTree build suggestions wanted
    I'm looking to add/upgrade a few items for next season. I've not changed my layout in several years and I want to add a few more items
    eaves trough pixels
    Large snowflake (pixels)
    singing bulbs/tree combo
    upgraded North Pole
    MiniTrees are on my list as my incandescent bulbs cannot be found in the quantities required.
    I can go retro and rebuild tomato cage mini's wrapped in C6 led strings using SSRoz 4 channel per tree
    OR
    I can try pixels
    My display is 270 degree viewable to the public
    Any images/suggestions for Minitrees would be appreciated.
    Cheers!
    Steve
    Learn 1 new thing everyday.
    "AURBO" -- Aurora Borealis
    My weather today
    Chambersburg, PA
    933
    Default Re: miniTree build suggestions wanted
    I'll follow this for suggestions for Mini Trees, but I would also like to recommend the StarFlake Spinner I designed a couple of years ago. The How To is in the Wiki as well as a Build Video from this summer's Virtual Christmas Summit. It might fit your need for the Large Snowflake, plus a whole lot more.
    2016 - No Display
    Nov 2014
    Close to Hillsboro, OR
    594
    If you are going pixels, there are a couple vendors that provide them. I bought the Boscoyo mini trees a few years ago and have loved them. 70 pixels (if you go full 360) each, 49 if you go for 270.
    Mar 2015
    Bloomingdale Ga
    298
    I changed mine this year. I was using tomato cages already and saw someone wrap the cage in chicken wire then do spirals with pixels
    and that's what I did as well. I really like the look. 100 pixels per tree. To me it's not a waste to wrap 360 as the ones on the backside
    I can see from the house and they just look GOOD! I used the 46" cages.
    Rayhjr I Love This Stuff!
    Buellton, California
    422
    I use 42" tomato cages wrapped in chicken wire for my mini trees. They've made the transition from incans to dumb RGB and now pixels. I have 62 of them in the display with 100 pixels each spiral wrapped. minitrees.jpg
    SLC, UT
    955
    I built non-pixel mini trees about 7 years ago. I didn't really like the narrow cone shape of the tomato cages so I built frames out of 1/2" PVC. I formed the base by heating and bending the bottom pieces using a jig so that I only needed T connectors. My display is only visible from the front (180° viewing) so I took the approach of using a "half" tree. This requires fewer lights to cover and as a bonus they can nest into each other to take up less space in storage. You could also do a full tree using the same design concept if desired.
    Here are some pictures:
    • Front and side view of PVC frame
    • Wood jig for bending PVC
    • PVC vs. Tomato Cage comparison
    Jig template was added to post #31.
    Last edited by ppohlman; 02-01-2021 at 06:39 PM. Reason: Added link to jig template.
    Chambersburg, PA
    933
    Quote Originally Posted by ppohlman View Post
    I like this suggestion! How long is each section of PVC pipe that you bent? Also how wide is the base and how tall?
    2016 - No Display
    Mar 2017
    Indiana
    178
    I build two mini trees with strips and tomato cage. Gives a spiral tree look.
    Lombard, IL
    700
    I made the change this past year from LED to Pixel on my mini trees. I used tomato cages for my trees and Boscoyo Pixel strips to hold the lights. I figured on a height that I liked and then adjusted it slightly to match the strips. When I figured out the final height of the cage and rolled rings for the top of the cage. These rings were welded in and the remaining material cut off the top to complete the tree. I made my trees 180 degree sing they only faced the street. So in the end I have trees that are 16 pixels high, 2 inch spacing, and 8 rows wide for a total of 128 pixels each. I built a total of 8 trees, one that goes under each of my arches. By using the strips the pixels are all aligned and the trees work like a matrix so patterns are easier to do. I can also scroll letters in them to spell words. They were a great addition to my display. Pictures can be provided if needed.
    Moorhead, MN
    125
    Anyone ever think about using an upside down fan trellis for mini trees?
    https://www.menards.com/main/outdoor...2308967&ipos=1
    https://www.lowes.com/pd/24-in-W-x-4...lis/1002647750
