Originally Posted by
ben&bobbi
I just did something similar this year. Instead of making the base portable, i just put it in the ground, so the top is flush (or slightly under) with the ground. I had a piece of PVC 4' in the ground that ended up partially filled with concrete. I cut the PVC a little lower in the ground than the base would be. On top of the PVC pipe, i put a galvanized coupler, then a galvanized extension, 6" i think, then the top coupler that the main pole goes into. The top coupler is about at ground level, then when the tree comes down, i will add anti-seize and a galvanized threaded plug. I do have a guy wire attached, and my tree is about 20'.
