Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: Ender 3 pro magnetic bed cover
  1. #21
    Kansas City Missouri
    2,748
    Default Re: Ender 3 pro magnetic bed cover
    215 for Petg? Seems awefully low. I have mine at 250 with 70 bed. Most people I've talked too run Petg around 250.
  2. #22
    Nov 2018
    Houston, Texas
    2,077
    I run. Petg anywhere from 215 to 240 depending on brand and how fast Iím printing . I donít think thereís a specific temp but the higher end does seem the most popular.
  3. #23
    6,953
    In Cura the auto setting for Generic PETG is 215 /70 so I went with it and it works very well for bright white filament but not so well for clear . 230 /70 seemed to work well for the clear .
  4. #24
    6,953
    Some late news from Creality . They are walking back the their first message of go purchase a new one .
    Dear customer,
    We are deeply sorry that you had such an unpleasant experience. We will try our best to help you to work it out.
    What is the temperature of the hot bed at which you use a soft magnet?
    Sorry for the inconvenience.
    Hope your reply.
  5. #25
    2,748
    I turfed the mirror and sticking with PEI for now . I don't like the idea of using glues and other materials to get a bond if not needed .
    The real test may be printing with nylon filament. I will order a spool to test with.
    Watched the video and that line on the left prints as a primer line. It's in the gcode of the printer. If I recall it's set to print 220mm and I changed it to 150mm. If you don't want it you can delete it in the printer setup in Cura. The brim, that circle around your print, is also set in Cura and you can also turn that off or adjust how many lines it prints. From what I can tell on the video, yours is printing 3 lines and default is 4 lines. I just print 2 lines.
  6. #26
    Nov 2018
    Houston, Texas
    2,077
    Canít get petg to stick to glass ?
    Perfect print 16 hours but had to sacrifice the mirror lol nothing used except glass cleaner
  7. #27
    2,748
    Sooner or later anyone using regular glass or mirrors will end up cutting themselves. It's not if but when.
  8. #28
    6,953
    I gave up on the mirror after just a couple of test prints , only tried with PETG and found it frustrating .
    I guess the mirror would not flex to release your part.
    While you were sleeping ,I was entertaining a 3d Printers nightmare !
  9. #29
    New Jersey
    1,402
    At some point, you have to accept defeat my friend. But, we feel you.
    Jeff
    Please consider becoming a Supporting Member of DIYC. Show your thanks to those who make this place possible.
