Thread: Watchdog Timer
    6
    Default Watchdog Timer
    This is an improvement taken from embedded programming. I have had several problems with a custom plugin failing and causing Vixen to crash. The improvement would reset Vixen and the programs if a error occurs. It would generate an error log to allow you to check and see what error ocurred. This improvement would prevent having to do a manual reset every time an error occurs.
    Bastrop, Texas
    978
    Default Re: Watchdog Timer
    Wow, too much information without a history...
    Can you break it down?
    Bob
    I love the smell of solder flux in the morning....smells like Christmas magic...[URL="http://photobucket.com/setup-2008"]Set up Done!![/URL] [URL="http://www.vimeo.com/rlilly/videos"]Showtime!![/URL]
    (for the fruit of light is found in all that is good and right and true) Ephesians5:9
    Oct 2007
    Ft. Worth, TX
    482
    You can't have a watchdog timer from inside the process being watched.
    You'd need a separate process to do that. If you're into Win32 programming it's really not hard... obtain a handle to the process and wait for it to become signaled in WaitForSingleObject. When it becomes signaled, kick off a new instance of the process.
    You could probably do the same in the .NET framework by wading through a few abstractions.
    (Of course, in this case, a better solution would be to fix the problem with the custom plugin.)
    There sure as hell *are* user-serviceable parts inside!
