Matrix on E682 and Xlights
I have built a Matrix with WS2811 pixel nodes. It is 42 nodes wide X 32 nodes High. Each string (4 Rows) is 168 Pixels connected to 1 output on the E682. (8 outputs - 8 Universes)
Controller Set-up
Xlights Set-Up
Running test patterns through controller is fine. Running test pattern in Xlights has an issue, Universe one is fine. Starting at Universe 2, the first two pixels are off which pushes the last two pixels to the next row. Then 2 off pixels which pushes 4 to next row and so on. Running a sequence it seems universes 1-4 are working correctly, from universe 5 onward everything is out of sync. I have tried using auto layout and this did not work. Any help would be appreciated.
Re: Matrix on E682 and Xlights
you have to change your starting Univ for out put 2-1 to Univ 4 ch 487. that should get you back in sync
Thank You Cdanna77.
That change along with changing Xlights channels per universe to 510 did the trick.
No problem. Oh didn’t see the 512 channel. Good catch.
Glad you got it going.
- You may not post replies
- You may not edit your posts
Forum Rules
