510 is the maximum, well, actually 512 is but you can make it less if you like. However, on a large show you won't be able to span channels across universes meaning it would take more universes for the amount of channels. You don't need to change the 510 or 512 on the controller, just assign each universe the number of channels you want. Your controller setup in your sequencing software also needs to reflect the channel count. By using less channels for each universe you will end up using more universes.
BTW. When using multicast you're sending data to every controller and the controller sorts out what it uses. If you use unicast it only sends info to the designated controller assigned ip.
