Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Current cheap transmitter
    Dec 2020
    1
    Default Re: Current cheap transmitter
    I got the "DSP PLL" one from Amazon. When it works, it does so very well. However, I am trying to use the USB mode where it appears as a sound device to the Raspberry Pi. This seems to work perfectly, as long as you "hotplug" the transmitter to the Pi when the Pi is already booted. If I reboot or power cycle the Pi with the device connected it fails to appear as a sound device to FPP. Confirmed with "lsusb" at the linux command line that the device is missing. If I hotplug the transmitter again, it continues to work perfectly until the next reboot.
    The most obvious workaround is just to use a 3.5mm cable to feed the audio to the transmitter and just use the USB for power. But I'm wondering if anyone has figured out how to make the device be detected from a cold boot?
    Chambersburg, PA
    936
    Quote Originally Posted by jfunk138 View Post
    I use a SoundBlaster Play3 connected to my RPi via USB, then connect to my DSP PLL using the 3.5mm cable. I have no issues with connecting and it also give FAR Superior sound quality. I have followed the recommendations of Jason Rasmussen from the Virtual Christmas Summit from last summer to Transmit your Audio over FM
    2016 - No Display
    Hicksville, New York
    226
    I use this with my Pi running FPP. I love it and it has RDS!
    https://www.adafruit.com/product/1958
    Crazy Light Addict.
    Chambersburg, PA
    936
    Quote Originally Posted by Spankyty View Post
    What kind of range do you get from this transmitter? The specs only say 30'.
    2016 - No Display
    Nov 2014
    Close to Hillsboro, OR
    594
    I'd love to use that one but I haven't done the research on how to hook it up to my system. I've got some time...maybe I'll look into it. Doesn't Dan Kulp offer a very similar board that uses the same chip?
    I do the same - power is supplied using an old smartphone charger (micro-USB). Again, I slapped an RF choke on the power cable to eliminate the noise that may be present on the DC voltage.
    226
    Oh right, I am on a residential block. I have a 2ft RC car antenna connected to it. LOL
    It dies out quickly after I say 100ft. But depending on the car I used, I could get up to ~225ft. (I used maps to help me measure the distance don't know how accurate it is.)
    Crazy Light Addict.
    226
    I don't know about dan kulps, interested though.
    If you are using a pi, it's simple.
    Add this plugin https://github.com/ShadowLight8/Si4713_FM_RDS then connect the wires like this:
    Pin 3 (SDA1) -> SDA
    Pin 4 (+5v) -> Vin
    Pin 5 (SCL1) -> SCL
    Pin 6 (GND) -> GND
    Pin 7 (GPIO4) -> RST
    Crazy Light Addict.
    1,766
    My understanding is that https://kulplights.com/product/fm-transmitter-si4713/ is an open source version of the Adafruit device (all Adafruit stuff is open source). If you compare pix, you see similar layout with very slight differences caused by the selection of the specific components. Pick either; they will work the same.
