if you make the arch pipe shorter and dont adjust the crossbar then your arches will get shallower. If you make thee crossbar shorter then the arch gets taller. you need to adjust them to make them into something you like.
I am setting up 4 large arches from Boscoyo and I completed my first one. I followed the steps shown on their website but I don’t like the space at the bottom of the arch.
Can I cut the PVC pipe to be less than 10 feet? Do I need to cut the 6ft EMT crossbar to a smaller size if I do this?
I have those arches and as Martin mentioned,it's trial and error to get the shape you like. I forgot what my dimensions were,but I did adjust them until I found a size I liked.
(1)Falcon PI Player (Running the show)
(1)Falcon F16V3
(1) Kulp K32A-B
(1)Renard SS16
(1)Renard SS24
(1)EDM-LCD-CS-EP
(20)P10 Panels
WIKI
Become A Supporting Member
Falcon Christmas
Renard Controllers
I want them a little shorter so maybe I’ll leave the cross bar at 6’. I want them shorter in height.
