Page 7 of 7 FirstFirst ... 567
Results 61 to 65 of 65
Thread: encode to esp32
  1. #61
    4,920
    Default Re: encode to esp32
    without an fs there can never be a configured ssid
  2. #62
    6,981
    Them dang ...little ffffffffffffs again . lol
  3. #63
    Jan 2021
    15
    Hmm. I have to wonder what you did. There is no way to uninstall the littlefs. Did you run gulp? Did you specifically upload the littleFS (it is not part of of the code upload).
    I had installed the fs through the library manager. when it pointed to a corrupt file I deleted the directory and reinstalled from the library.
  4. #64
    4,920
    Quote Originally Posted by firemedic04 View Post
    i meant how did you install littlefs onto the esp. you need to run gulp to create the fs image files and then littlefs uploader to get that image to the esp.
  5. #65
    Jan 2021
    15
    Im Done with this for now. When flashing the littlefs with the ESP32 tool I get mklittlefstools not found. So when looking back at the log files during install, when installing node and running command, npm install -g npm, I get an error " resource is unavailable it is open or antivirus is blocking access". npm install -g npx does nothing from this point as it returns, file is missing. npm install -g gulp-cli again returns, file is missing. I have run these commands as admin. I have tried disabling the windows defender. I have had it with windows 10. after multiple attempts of installing it, I give up. Sorry if I have wasted your time. Again, I thank you for your efforts. When Im not so frustrated and not likely to damage anything I will try this on a different system..
