Issue 1; This has been fixed with the latest update. Download the current version and you'll be good to go
Issue 2; Did you happen to have Vixen open while you were playing the sequences in FPP?
To start, my Halloween show went off great w/o this issue. So, after added the rest of the display, I only tested two/three songs and all looked great. The Halloween and test was probably done w/ DevBuild 991-994. Last night, I have two issues, when I uploaded one specific exported sequence, and addd it to the playlist - it showed the time as all zeros. Which meant that when I reached that song, the playlist went into a loop to the beginning. Removing the song from the playlist solved the loop. Still do not know why it displays all 0000 in the playlist. Issue two, more dramatic, all songs seem to be out of sequence and the lights flicker. See video. To validate, I then connected my PC and sent the playlist out from Vixen and I had no issues.
https://www.dropbox.com/s/wx3e3pq84a...17782.MP4?dl=0
2016 Migrating to Vixen 3.2
Vixen 2.5x
120 Channels
2015 5 RenardSS24 @ 20,600 lights
2014 5 RenardSS24 @ 18,600 lights
2013 3 RenardSS24 @ 9,900 lights
2012 2 RenardSS24 @ 6,000 lights
2011 began researching
[url]www.KentlandsChristmas.com[/url]
Vixen 2.5x
120 Channels
Vixen 2.5x
120 Channels
Vixen 2.5x
120 Channels
Did you say you were also having an Issue w/ the sequence lagging behind the music? I noticed that on mine too but was able to fix it by going to the Advance FPP settings adding a delay to the Media\Sequence setting of -1000ms (still tweaking)
Mine too. I always had an offset in FPP, but i discovered a recent FPP update had set the offset back to 0. In my system, I found -350 to be very close to perfection.
The problem that we fixed for FPP export would not have caused flicker. That would have caused sequences to not play at all. It had to do with some bad math in calculating offsets in the fseq header in certain combinations of channel counts. (rounding error) FPP couldn't validate the file and would therefore do nothing at all with it. You wouldn't have seen flicker.
My Display: www.facebook.com/ChuchlaFamilyLights
My Videos: www.youtube.com/jchuchla
My Pics: http://photos.chuchla.com/?aid=606
I did. It have a chance to test anything today-rain kept me away. Someone suggested that I may have had vixen on my PC on, not running a show, just on and that may have caused it. What is frustrating is that I can get about a half a song in before all goes to hell. Then it never recovered.
Vixen 2.5x
120 Channels
So, today I unplugged the PC and I only have the PiCap running and thus far, the "light only show" is not blinking to cause nausea! At 6pm, the lights w/ music starts and I am hopeful.
Vixen 2.5x
120 Channels
