I set up a new Vixen 3 sequence from scratch, the channels did the same thing. So it's not a Vixen 2.5 issue.
I swapped pics in the controller before the issue the controllers ghosting (25 to 64) with no luck.
If I unplug the controller for 57, the lower channels remain off when 57,58 and 59 are supposed to be on.
Ok, I have a wreath and a window plugged into 57,58 and 59. If I unplug the wreath, everything is good. I thought the wreath was causing it, but if I plug new lights out of the box, same results. Incans do not cause it to happen. If I move the wreath to another window all is good. I'm baffled, my head is hurting at this point, but at least the glitch is out of the show.... but I would like to figure out the why. The other windows are on the same power source as the original window. I also tried swapping boards controlling that window.
