Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: FPP Raspberry Pi 3B+ No Audio
    4,919
    Default Re: FPP Raspberry Pi 3B+ No Audio
    Interesting. I asked because the PIs do not like power removed. It is also possible the flash card developed a bad sector. Those are just two of hundreds of things that can go wrong.
    Folsom, CA, USA
    2,265
    Quote Originally Posted by davdue View Post
    My solution was reflash but don’t use the restore. My backup had a problem. So I had to re-enter all my configuration data. Fortunately I had screen shots of it all. Good luck
    Now that you have everything working - it's time to do an update - 4.6 released at noon today.
    http://falconchristmas.com/forum/ind...html#msg116101
    Edit: Then upgrade the update to 4.6-2
    In Lights Therapy
    Sep 2007
    Valley Center, Ks
    527
    Not going to happen. I wouldn’t have upgraded at all if it hadn’t gone tango uniform on the audio.
    Dave-2990Px-20KLts
    Dec 2019
    6
    I just had this happen to me. I enabled two outputs on the Channel Outputs / Pi Pixel Strings tab, which apparently disables onboard audio according to this thread:
    https://auschristmaslighting.com/thr...y-audio.12747/
    Once I went back into the Pi Pixel Strings tab and disabled the outputs, I was able to select Pi Onboard Audio from the FPP Settings / Audio/Video tab. Hope this helps someone else that sees Dummy for the audio output.
