I never tried that jack. I use a soundblaster 3 via. USB port on pi
Everything worked fine last night. Today I was doing some testing to fix a few issues with pixels and other items. Got those fixed with the display testing page so I decided to play my playlist and no audio. I use the 3.5mm jack on the Pi to a FM transmitter. I have swapped out the Pi, FM transmitter, and audio cable and nothing fixes it. I was checking the FPP settings page (FPP V4.2) and the Audio Output Device setting only has dummy for a selection. Shouldn't I have some more settings like analog? I don't even see a FPP global settings page like the manual shows on page 38. Show runs in 4 1/2 hours. Ugh!!!!
Dave-2990Px-20KLts
Did you play the playlist from the status page?
Kevin
The issue is in the audio tab on the FPP Settings page. As long as Dummy is the only selection, you are stuck. If you are using the on board audio, you need to select the BCM.... audio device. If the device is not present then you have not enabled sound in the base PI configuration (Usually done for you by the FPP installer). I had my master PI lose the audio configuration yesterday. Not sure why or how. I went into PI Config and enabled my sound device (again) and then went into the FPP settings page to select my sound card (I use an audio DAC PI Hat).
Is this where I need to put it back in? I tried to replace Dumm with BCM and it didn’t work.
Dave-2990Px-20KLts
Make sure you have installed the latest version of FPP. Then you should set up the audio like the picture below. The FPP installer sets up all of the support files. I suggest formatting the SD card and then installing the FPP image using an image writer. The format step is important to ensure any lingering file issues are erased.
So are saying I have to start over with the FPP install. This was working fine last night. I made no changes to the FPP today and it doesn’t work. Something must have gotten corrupted. Since I only have dummy as a selection. What did you mean when you said you had to go into the Pi Config and re-enable the audio?
Dave-2990Px-20KLts
I have been using Linux for twenty years. I am comfortable walking through the various config tables when they get corrupted. When I do not know the level of Linux familiarity of the person I am talking to, I will recommend the safest route to getting an issue resolved. Here is what I have: You and I both experienced an issue with the sound on the PI. I noticed that my issue showed itself after an unusual hang in my FPP. When I investigated I found that critical 'SYSTEM' config information for my configuration had been deleted (no idea why). I went through the Linux tables and manually repaired them. I would hate to try to walk someone else through that process. I know that the latest Linux/FPP build sets up those tables properly. So here is what I am suggesting to you. Save your FPP config to your PC. Rebuild the FPP using the latest files from Falcon. Restore your config from your PC to the FPP. Correct any issues that may be in the config due to the corruption on the PI.
The low level PI config is called raspi-config and you can find information about it here "https://www.raspberrypi.org/documentation/configuration/raspi-config.md". This program is executed in the linux shell as root. It allows you to set up the hardware and other features of the PI. In my case the busses I needed had gotten turned off and the control files in /etc had gotten changed. WARNING: Modifying settings using this utility can leave your PI unusable. Use at your own risk.
