Thread: Vixen 3.7u1 Build #996 Crashes after any MP3/WAV Association
    Nov 2020
    2
    Default Vixen 3.7u1 Build #996 Crashes after any MP3/WAV Association
    Hey gang, I'm new and this is my first time running Vixen on my Alienware 17R4! Here's the fatal log:
    11/19/2020 00:24:52.803 [VixenApplication.Program] An application error occurred. Please contact the Vixen Dev Team with the following information:
    System.Exception: Sound system error (ERR_UNINITIALIZED)
    This command failed because System::init or System::setDriver was not called.
    at VixenModules.Media.Audio.FmodInstance.checkErrors( RESULT result)
    at VixenModules.Media.Audio.FmodInstance.LoadAsSample (String fileName)
    at VixenModules.Media.Audio.FmodInstance..ctor(String fileName)
    at VixenModules.Media.Audio.Audio.LoadMedia(TimeSpan startTime)
    at VixenModules.Media.Audio.Audio.get_MediaDuration()
    at VixenModules.Editor.TimedSequenceEditor.TimedSeque nceEditorForm.AddAudioAssociation(Boolean showWarning)
    at System.Windows.Forms.ToolStripItem.RaiseEvent(Obje ct key, EventArgs e)
    at System.Windows.Forms.ToolStripButton.OnClick(Event Args e)
    at System.Windows.Forms.ToolStripItem.HandleClick(Eve ntArgs e)
    at System.Windows.Forms.ToolStripItem.HandleMouseUp(M ouseEventArgs e)
    at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEven tArgs mea)
    at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at System.Windows.Forms.ToolStrip.WndProc(Message& m)
    at Common.Controls.ToolStripEx.WndProc(Message& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) at VixenModules.Media.Audio.FmodInstance.checkErrors( RESULT result)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) "
    I tried several mp3's and wavs and still crashes. My PC's sound drivers (Realtek Audio-driver 6.0.8816.1) are updated and are working properly. Any suggestions?
    Maryville, Illinois
    1,898
    Default Re: Vixen 3.7u1 Build #996 Crashes after any MP3/WAV Association
    Check what device is set to default for the output on your system. Generally that error points to some odd device being the default.
    Nov 2020
    2
    I got it working! Per jeffu231' suggestion, I was able to isolate the problem preventing Vixen from associating music files by disabling startup applications, one by one, until it no longer crashed. I found out if I disabled "Alienware Sound Center.exe," Vixen was able to load MP3's with no problems.
    Fix: Rather than rely on Windows update to keep my sound drivers current, I just went directly to the Realtek website to manually download and reinstall the the sound drivers. Now Vixen doesn't crash, even with formerly problematic file enabled at startup. Bottom line: Reinstall the sound drivers.
    Thanks!
