Results 1 to 4 of 4
Thread: Projector control question
    Saint George, UT
    100
    Default Projector control question
    I have a Viewsonic projector hooked up to my RPi 3+ with FPP 4.4 loaded. I connected the projector using a USB-Serial adapter. I tested the commands with a PC and they all work. I verified the commands are the same as in the GitHub file. Problem is I can't get FPP to control the projector. I tried running the ON command with the playlist. Is there something else I have to do besides just select Projector On? I verified baud and all that. It listed ttyUSB0 in the serial device (no other selection available). Since it works using the PC (with a serial control program) I thought it should work with FPP. I looked all over trying to get info on this but didn't find anything.
    Any ideas?
    Nov 2018
    Houston, Texas
    1,943
    Default Re: Projector control question
    I run mine from my pi3 b in remote and works great other than having to hit power button
    Saint George, UT
    100
    I'm using the video output from the pi3 and it works fine. I want to set a schedule and turn on the projector automatically.
    Saint George, UT
    100
    Finally figured it out. I had the turn on command repeat box checked. Unchecked that and it works!
