Results 1 to 4 of 4
Thread: FPP Master Remote
    Jan 2019
    Paola, KS
    29
    Default FPP Master Remote
    I just have a question about why you would need a FPP master and remote(s). I guess I am not sure about the relationship and how and why to use this type of setup?
    Nov 2015
    46
    Default Re: FPP Master Remote
    Hey Tomas, I have a Mater/Remote setup. I have my master running all the pixels on the outlines on my house and I have a PI remote on the lawn that I run my mini trees on. I run my Pixels off pin 18 and 19 of the PI and they have a limit to how many pixels you can run. Also there is a limitation on distance for the data connection.
    Kansas City Missouri
    2,650
    Remote also used to run panels.
    4,557
    Quote Originally Posted by tomas041857 View Post
    There are a number of reasons. The biggest is network congestion. A bunch of PIs with local network switches (I use the small 5 port models) close to groups of controllers limits the amount of data each PI has to put on its local network span. I also have a PI close to my Renards. Renards use serial data. The PI generates serial data using USB to serial adapters. USB cables need to be relatively short so co locating the PI helps keep the wires short. Non of my F16s are close enough to the Renards to make a connection clean so the co located PI is my top choice. I also use a PI to drive my tune to sign. The sign is too far away any F16 so again, a colocated PI solves my data generation issue. Can all of these issues be solved in other ways? Sure. Did I have a bunch of PIs sitting around that made this an easy choice? Yup. My solutions may not be best for your issues. Just remember that you can think outside the box and come up with creative solutions for your problem set.
