Results 1 to 2 of 2
Thread: LOR controller into F48 controlled by Xlights
    Dec 2017
    Louisiana
    4
    Default LOR controller into F48 controlled by Xlights
    Greetings from Louisiana,
    I hoping someone can help me with my issue.
    Simple Version: I can't get an Xlights sequence to light my AC lights
    My setup:
    Using Xlights, FPP in standalone to F48. F48 has several outputs of pixel data, all working with ZERO issues.
    I have a 16 Channel LOR controller connected to serial 3 of the F48.
    I can run the test function at the F48/Falcon network interface, through the FPP interface, and in Xlights. When the test activates the channel assigned to the AC lights they come on just fine. BUT I can't get them be recognized in a sequence in any way. They also won't function in "output to lights" mode. Only in test within Xlights. What am I missing here?
    What do my model settings need to be?
    Screenshots attached.
    PS: Non-important, Side-question, can I control individual channels on the LOR contoller, or is it all or nothing?
    1,545
    Default Re: LOR controller into F48 controlled by Xlights
    Is 4990 the right start channel?
    You should be able to control each channel independently.
