Thread: Exported sequences not opening on FPP
    Nov 2010
    5
    Default Exported sequences not opening on FPP
    I have 2 FPPs running 4.4 and neither one will play sequences exported from Vixen 3 - 3.7u1.
    If I put the FPPS in bridge mode sequences play correctly directly from my PC.
    If I export the sequences out of vixen as a vixen sequence, and then use xlights to convert them to fseq those play on the FPPs without a problem.
    I am fairly confident I have all my controllers setup correctly. I have a complex setup -I am on universe 122 now I think. But I can post settings if you want.
    Is anyone else having this problem? Am I missing a setting that will fix this?
    Maryville, Illinois
    1,889
    Default Re: Exported sequences not opening on FPP
    Try the latest dev build. There was a bug in the export that affected certain combinations of sequences that was fixed. You can try exporting without compression and if it works, then that bug fix will likely solve it for you.
    3
    Thank you so much for this. I have been pulling my hair out for a week. Some sequences still didn't work the first time but after exporting the second time they are working.
