Results 1 to 9 of 9
Thread: Starting/stopping LTC at specific times ...
    1,500
    Default Starting/stopping LTC at specific times ...
    I'm something of a Windows XP neophyte (what can I say, it's been all Mac and/or Unix), so I'm not 100 percent sure how to accomplish this:
    I have two *.led sequences I want LTC to run, one starting at around 3 p.m. and then ending at 6:25 p.m., and then the other starting at 6:30 and running until 10 p.m. I have the Windows machine on a lamp timer and it turns on at 3 and turns off at 10:30 (I have XP scheduled to do a shutdown at 10:15); the PS for the Triks/Triks-C is on the same timer.
    I know about XP's Scheduled Tasks, but it will only launch an application, which doesn't help me with the LTC parameters. How do I run something at a specific time that has that long string?
    TIA.
    \dmc
    Melbourne Australia
    551
    Default Re: Starting/stopping LTC at specific times ...
    Could you run a batch file?
    ie create a text file called 'startup.bat'
    inside startup.bat put the ltc and parameters
    1,500
    Quote Originally Posted by TimW View Post
    OK, that starts it ... what can I do to stop it so I can start another one?
    \dmc
    montreal,quebec
    207
    you could have 2 file like 300.bat and 1830.bat and use task scheduler in administrative tool in windows
    :DThanks !!
    Serge
    New Zealand
    54
    what I do is use a batch file to run ltc which uses a text file for commands.
    ie
    file name : start.bat
    c:\ltc.exe script.txt
    and then have another batch file that kills the ltc.exe task
    ie
    file name : end.bat
    tskill ltc.exe
    for more info google "tskill"
    so you could do as shocker suggests and use 2 batch file in scheduler to start ltc and another to end it.
    hope that helps
    cheers
    kiwichristmas
    1,500
    Quote Originally Posted by kiwichristmas View Post
    That's the puppy I was looking for.
    Thanks.
    \dmc
    Jul 2007
    Curtice Ohio
    218
    In XP - In the schedule task properties - Settings tab
    Under Scheduled Task Completed
    Check - Stop the task if it run for: (Set the duration)
    This will kill the app after the duration you set. Has worked every night for me so far.
    1,500
    Quote Originally Posted by cobraman44 View Post
    That was going to be my next course of action. But tskill works, as long as you remember this:
    When using tskill don't put .exe in the command
    So, the line in the bat file would be:
    Code:
    tskill ltc
    \dmc
    San Dimas, CA
    410
    with in scheduled task you can pass command line switches. I do it all the time at work use the following syntax:
    cmd.exe /c "defrag.exe c: -a -f -v"
    that passes it the c: -a -f -v switches, you can pass as many as you like. I have some process that use 5 and 10 different switches.
    Truth is a three edged sword....
    Embassador Kash Vorlon Empire
    http://www.tgconley.com
