You should be able to use the Megatree Smart Object. If you are having trouble making it smaller with the mouse try typing the numbers for it on the settings section.
I use this exact method for pixel poles and they look great.
Hi All,
While I have used a smart object Mega Tree prop in the Preview Config. However, at on point u are limited how thin to make the column, at that point it reverts back to a tree or triangle. So, does anyone have a Vixen prop to share?
2016 Migrating to Vixen 3.2
Vixen 2.5x
120 Channels
2015 5 RenardSS24 @ 20,600 lights
2014 5 RenardSS24 @ 18,600 lights
2013 3 RenardSS24 @ 9,900 lights
2012 2 RenardSS24 @ 6,000 lights
2011 began researching
[url]www.KentlandsChristmas.com[/url]
You should also be able to make it using the matrix tool. You can make it as many rows and columns as you need.
Vixen 2.5x
120 Channels
You might also consider changing the top and base heights. This will make the column top and bottom "flat" if you use zero as the setting.
