Results 1 to 10 of 10
Thread: Trouble sliding pixel strips into 1/2" pex.
    North Vancouver, BC, Canada
    1,007
    Default Trouble sliding pixel strips into 1/2" pex.
    I'm building the bwinter icicles which is two 60/m ws2812 strips of 30 leds each back to back with a return wire. I didn't realize he used bare strips and had already ordered and cut the ones with a sealant over top. Luckily there is just enough clearance inside to technically squeeze it in without compression. However when I get about halfway down the icicle, with the flex, when I try to push to slide it further, it's making the strips push outwards which then catches the pipe wall and it bunches up. Trying to figure out how to get smoother sailing to avoid damage, but lubricant seems like a bad idea. Ideas? It's not sticking technically, it's more like catching it a bit
    SF CA
    544
    Default Re: Trouble sliding pixel strips into 1/2" pex.
    Is everything in a shrink-wrapped sleeve?
    1,442
    Tie a string on the ends and pull instead of push.
    6,629
    Lube ?
    1,007
    Lube ?
    Well I'm a bit paranoid about having moisture inside of it. Wait. Are you asking what I mean by lube? Or suggesting it?
    1,007
    That's one way to do it. The clearance is pretty tight. I'm wondering where to tie it on
    6,629
    Yes. Lube it with talc or baby powder if sunlight doesn't appeal.
    1,007
    That was an idea I had thought of. Wasn't sure if it was a problem or negative to have fine powder in the strips
    Sent from my SM-N960W using Tapatalk
    6,629
    lube the inside of the pipe not the strip .
    use tie wire to pull the strip through .
    that's how i did my matrix.
    Sep 2019
    8
    Rubbing alcohol is a fantastic lube. It lubes the pipe and then evaporates away...
