Results 1 to 10 of 13
Thread: 5v power supply max rating
    Jan 2019
    78
    Default 5v power supply max rating
    What would be the max rating of power to be used? Can I use 1 70a 5v PSU vs several 20a? I thought I once read that a bigger supply doesn't really work like that. Say I want to push power to 400 pixels with one supply instead of 2-3 supplies of smaller rating
    6,620
    Default Re: 5v power supply max rating
    You sure can . These are what I use for 5v pixels .
    For your 400 pixels at max brightness 24A is the believed current draw , so a 30A power supply would be sufficient .
    Chambersburg, PA
    813
    I use the same PS for all my 5v pixels as well. I get mine from Holiday Lighting. Chris is a member here and has a great selection, pricing, and quick service.
    2016 - No Display
    2020 - All Wireless with ESP>RS485 converters for AC controllers and PixelSticks for all pixel props
    Jan 2019
    78
    I have a 20 amp and I cant get past 150 lights. I have a 672 node matrix in 5v trying to find power options so by that standard one 70amp should power the whole thing
    Chambersburg, PA
    813
    Are you injecting power to your pixel string? 5V can only power about 50 pixels without injecting more power. I would have power injected at pixels 1, 100-101, 200-201, 300-301, 400-401, 500-501, 600-601, 672. Your entire matrix at 100% brightness and all White should only draw a little over 40A.
    HTH
    2016 - No Display
    Jan 2019
    78
    Max rating you guys state vs injection and how many pixels per power injection, I think I have been misunderstanding injection..... I use the same power supply not different ones but need a + wire from PSU to injection point on pixel?
    I will take a +/- to pixel 1 through 100 then same power supply take a - just for added ground resistance with + from same power supply to pixels 101-200, ect, ect
    So if I do that I don't need say 6 PSU's just 1? So an injection point don't mean a new PSU just an additional +/- from same PSU?
    6,620
    Correct.
    Jan 2019
    78
    Correct.
    One more quick question? When injecting power from same PSU do I need to break the + between them? I watched a video where the guy did not if it was same PSU only if using a different PSU
    6,620
    Correct . No breaking needed for same supply . If subsequent supplies are added v+ needs to be independent .
    Sheboygan, WI
    1,716
    Quote Originally Posted by mojuave1 View Post
    Yes when injecting power you need to isolate the +v on each power supply. You must tie the grounds together.
