Results 1 to 2 of 2
Thread: Text Effect Not orking after Upgrade to 3.6u4 build #937
    Southern California
    969
    Default Text Effect Not Working after Upgrade to 3.6u4 build #937
    The Text Effect is not working on several sequences that were converted from earlier version to 3.6u4. I upgraded the software a couple of months ago. I created a bug report but wanted to see if anyone else has seen this problem. May also affect other effects.
    Text that is supposed to run across my MEGA tree does not show. The base color will come on but no text.
    Kevin
    Southern California
    969
    Default Re: Text Effect Not orking after Upgrade to 3.6u4 build #937
    As mentioned, I had submitted a bug report and Jeff U. started working on it right away. He found the problem was not a bug but a configuration issue on my end. I had not linked my Display Elements to the Preview Elements correctly. He showed me how to fix it and now all of my sequences are working correctly.
    Thanks Jeff.
    Kevin
