Results 31 to 36 of 36
Thread: Flickering Pixels (i.e. bad blinky-flashy)
  1. #31
    Nov 2013
    Butler, PA
    25
    Default Re: Flickering Pixels (i.e. bad blinky-flashy)
    As an update:
    I received the MOSFET and voltage regulators I order from Mouser. I assembled a board with those two parts and all of the other 'September' parts. The board seems to work properly now. As someone mentioned above about there potentially being a voltage issue with the data signal, I wonder if the voltage regulator is necessary even when 5V pixels are being used...
    I think I might try the old MOSFET on one or two of the new boards to test my theory of needing the voltage regulator even with 5V pixels. I just wanted to let everyone know of my progress thus far.
  2. #32
    Nov 2013
    Butler, PA
    25
    I assembled a board with the old MOSFET and the added 5V voltage regulator in IC1. Everything works properly with no flickering.
    It would appear that the voltage regulator is necessary even though I am running 5V pixels. It's possible that it's an issue with these particular pixels (not from Ray Wu (see above)). In any event, I will continue to assemble the two dozen or so boards I'm gonna use for my display and post an update if I have any issues related to the flickering I was experiencing before.
  3. #33
    6,634
    Thank you for keeping us in the loop as to your progress and findings .I may have to dig out the pixel pops once again after all !
  4. #34
    Nov 2013
    Butler, PA
    25
    Hey everyone,
    I have been assembling more Pixel Pops. I have seven of them driving nearly 1200 pixels mounted in several of my windows. Since I have started including the 5V voltage regulator in IC1, I have not experienced any more of the previous flickering with my 5V pixels when no data is being sent to them. I will try to remember to report back my experience after another few weeks or so, but based on my experience, I plan to include the 5V voltage regulator on all of my Pixel Pops.
  5. #35
    6,634
    Quote Originally Posted by davwav02 View Post
    Hey everyone,
    What power supply are you using ? Specifically?
  6. #36
    Nov 2013
    Butler, PA
    25
    I am using PC power supplies. I cut all of the PC wires out and soldered lengths of SPT-1 (left over from my AC strand lights used in years past) to the 5V wires running to each Pixel Pop.
