Results 1 to 10 of 10
Thread: P10 module
    May 2013
    85
    Default P10 module
    Hi all, can someone please tell me which adapter do I need to run p10 panels 1/2 scan rate. Do I need a raspberry pi or a beaglebone.
    Kansas City Missouri
    2,613
    Default Re: P10 module
    Quote Originally Posted by waites View Post
    I used to use a Pi but had flickering issues. There are only 3 outputs for the matrix using a Pi. I switched to a BBB and this adaptor and never looked back. Other folks use a colorlight for their panels. This adaptor has 8 outputs for the BBB.
    http://www.renard-shop.com/home/60-o...ller-cape.html
    May 2013
    85
    Thanks pmiller for your help, do you know if this is already assembled or a kit.
    2,613
    It says kit. It also says out of stock.
    Nov 2014
    Close to Hillsboro, OR
    537
    You can also get one from Dan Kulp that provides a couple extra features if you are willing to spend a few extra $$$ -- https://kulplights.com/product/octoplus/ On that web page is a link to Wired Watts, another vendor that sells the device.
    May 2013
    85
    Thanks a lot
    May 2013
    85
    Hi. I had already a raspberry pie matrix adapter, using vixen lights, but I just can get it working. Does any of you know how to set it up using vixen.
    1,438
    Does your adapter work from the rPi?
    You usually just export the matrix data (or the whole sequence) to a fseq and then load that on the rPi. From there, the setup is on the rPi.
    May 2013
    85
    Hi MIke, the only way i tried was using bridge mode(no sequences load yet) this is the setup i have, do you thing i have something wrong?IMG_3892.jpgIMG_3909.jpgIMG_3910.jpg
    Thanks.
    2,613
    Thanks.
    I noticed you don't have "enable LED panel output" checked. You also only have 1 panel in your setup. You need to complete FPP setup with the correct number of panels, 1/2 scan and panel configuration.
