Results 11 to 20 of 24
Thread: Vixen 3.7 Released
    Mar 2015
    Bloomingdale Ga
    298
    Default Re: Vixen 3.7 Released
    We need to see some logs. We have a couple people reporting crashes and others that are working just fine. Many folks have been using the dev builds all along so there is something odd going on. If you want to create a ticket at bugs.vixenlights.com and attach your logs, we can take a look and see what is going on.
    Done. If you need more info let me know.
    Thanks BTW for this and all that you do on this Great Program.
    Rayhjr I Love This Stuff!
    Mar 2015
    Bloomingdale Ga
    298
    Well I would have sworn that I tried to open "setup Preview" before and it worked but now it does the same thing. I can open the preview window, click on my preview then click on "configure preview" and it crashes. Probably th same problem if you need more logs for this let me know.
    SOLVED
    Maryville, Illinois
    1,934
    Quote Originally Posted by rayhjr View Post
    SOLVED
    Just in case others are reading, it looks to have been an incomplete install due to aggressive anti virus. It was solved with a reinstall. We tend to see a few cases of this each time we update until the AV products get the new version in the clean list.
    Conyers Ga
    37
    Is there any reason the lip sync tool isn't working? I have used it prior to upgrading to 3.7 without any problems, the sequences I had done before upgrade are working fine, new lip sync is not coming up on the screen just blank boxes.
    Broken Arrow, Oklahoma
    634
    That corrected my issue as well. thanks.
    [SIGPIC][/SIGPIC]
    Maryville, Illinois
    1,934
    Quote Originally Posted by cymbiline View Post
    I have been using the lip sync the last several days and it is working for me. Can you describe which approach you are using?
    Mar 2015
    Bloomingdale Ga
    298
    I found another issue. When using the WAVE Effect and I try to "Add" or "Remove" a Wave, Vixen crashes. Not sure if it is related to my previous issue or not.
    Created a Ticket.
    Conyers Ga
    37
    I set up my own marks by right clicking then pull up the tool lip sync then lyric converter select the per mark collection type in my word or phrase hit convert and I get empty boxes. I had done a few lines a few weeks ago and I thought thats how I did it then. I could be wrong
    Conyers Ga
    37
    I also just tried to do lipsync in the add effect section it also doesn't put the words up on the screen just blank boxes. Also tried downloading the 32 bit version instead of the 64 bit same thing.
    Can I do a roll back on this software to a previous versuion?
    Maryville, Illinois
    1,934
    Can you zip up the profile and PM me a link to a dropbox or google drive link so I can take a look at it. Point me to a example sequence that is not working so I can see it. I suspect there is something simple missing.
