Results 1 to 10 of 24
Thread: Vixen 3.7 Released
    Maryville, Illinois
    1,934
    Default Vixen 3.7 Released
    Vixen 3.7 has been released.
    Release Notes
    Improvements
    [VIX-989] - Improved Zig Zag Support
    [VIX-2275] - Double click on a controller name should open the configure form rather than unfold the channels
    [VIX-2750] - Add Progress Dialog while profile is loading
    [VIX-2786] - Add flip vertical and horizontal options to toolbar in custom prop editor
    [VIX-2787] - Add detents when rotating a selection while holding a modifier key in the Custom Prop and Preview editor.
    [VIX-2890] - Update all dependencies and prepare for moving to .NET Core.
    [VIX-2893] - Box2D contains warning/error when compiled under latest VS2019 Update
    [VIX-2895] - Update Snowflake effect to include a grid pattern
    [VIX-2896] - Make start of liquid effect movement deterministic
    [VIX-2904] - Move the effect pop-up info box in the editor
    [VIX-2916] - Migrate TeamCity workflows to GitHub Actions
    [VIX-2924] - Ability to set Export timing to the same as the Update Interval
    [VIX-2927] - Improve Face imports for analog props and provide better Lipsync effect defaults.
    [VIX-2929] - Improve the config and sequence file backup mechanism.
    [VIX-2943] - Modify Shockwave to use scaled radius curve.
    [VIX-2958] - Add ability to reverse a group of selected elements in the wire order tab of the Custom Prop Editor
    New Features
    [VIX-2120] - Add polygon effect
    [VIX-2933] - Add a feature to duplicate a preview
    Bugs
    [VIX-2601] - Crash when using pinwheel effect
    [VIX-2792] - Vixen 3.6 Set Level not working, on some elements
    [VIX-2851] - Setup Display - Undo refresh
    [VIX-2863] - Wave Effect - Improve Mark Support of Decaying Sine
    [VIX-2889] - Incorrect speed on effects
    [VIX-2899] - Bars Effect Bug (with workaround)
    [VIX-2900] - Shapes no longer working
    [VIX-2903] - Dev Build Crash; Preview has completely disappeared
    [VIX-2905] - Waveform effect missing from current dev builds.
    [VIX-2911] - Incorrect speed on Video effect after Update Interval is changed to 25ms
    [VIX-2917] - Particle Intensity on Liquid Effect will not Save
    [VIX-2920] - Fix unneeded fields exposed by recent Catel upgrade in Prop Editor
    [VIX-2922] - Reference to Liquid (Emitter) Effect in common code
    [VIX-2932] - Preview zoom gets stuck if you zoom to far in or out
    [VIX-2934] - Text effect introduces a small gap or blink after saving and reopening
    [VIX-2936] - Export Sequence Package not working
    [VIX-2941] - Make ExpandObjectObservableCollection Abstract
    [VIX-2942] - Preview Star does not detect Pixel or Standard properly when linked.
    [VIX-2952] - Custom prop selection in preview not working correctly.
    [VIX-2953] - Morph causing Vixen to freeze
    [VIX-2955] - Token replacement window title "naming" needs capatilized.
    [VIX-2957] - Custom prop editor has several minor bugs that can lead to a troublesome experience.
    [VIX-2959] - The wire order diagram menu in the display setup may not be enabled when it should be.
    [VIX-2960] - The profile Lock file may be empty an cause an error.
    [VIX-2961] - Scheduler can hang if sequences have not been migrated first.
    Oct 2009
    25
    Default Re: Vixen 3.7 Released
    Vixen 3.7 includes a new Morph effect. There is a video on YouTube giving an overview of the effect's capabilities.
    https://www.youtube.com/watch?v=phoCw_kFld4&t=2s
    West Bloomfield, MI
    716
    Fantastic! Thanks again to the whole crew for all the time that goes into these updates. It's much appreciated!
    Ed
    Happily retired
    Aug 2013
    Surprise, Az
    658
    Great job, guys! Thank you!!!
    Kenai, Alaska
    125
    Thank you for all the hard work and keeping Vixen 3 as great software for my light show!
    Dec 2015
    Bay Area, CA
    64
    Thanks for the update. Love the morph effect. I think the Wave effect is broken though. When changing the styles the preview (nor the effect in the sequencer) changes at all
    Mar 2017
    Indiana
    179
    Thank you for all the work you all do on Vixen!
    Oct 2009
    25
    I have reproduced the problem with the Wave effect. Sorry, I made a mistake in some maintenance on that effect. I am submitting a fix. I assume it will be included in an update "U1" to Vixen 3.7.
    Mar 2015
    Bloomingdale Ga
    298
    I updated last night and today whenever I click on "Setup Display" the program shuts down. Any ideas?
    SOLVED
    Rayhjr I Love This Stuff!
    Maryville, Illinois
    1,934
    Quote Originally Posted by rayhjr View Post
    We need to see some logs. We have a couple people reporting crashes and others that are working just fine. Many folks have been using the dev builds all along so there is something odd going on. If you want to create a ticket at bugs.vixenlights.com and attach your logs, we can take a look and see what is going on.
