Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
Thread: Will 1/2" (usually) grey schedule 80 pvc conduit work well with pixel bullets?
  1. #21
    Sep 2016
    Phoenix, AZ
    39
    Default Re: Will 1/2" (usually) grey schedule 80 pvc conduit work well with pixel bullets?
    2 3/4 inches plastic bottom of the bulb to plastic bottom of the bulb. Holes are 2 1/4 (or some are 2 5/16) center to center.
    And Oh, BTW, if you take a 3/4 inch EMT pipe holding bracket (pipe bracket with mounting hole on one side only) and bend it slightly smaller with a crescent wrench, the 1/2 inch PVC snaps right in like it was meant to. Then I just hang the pipe/light assembly from my eave using small hooks. 50 pixels fit just under a standard 10 foot pipe (about 9 1/2 feet), and I use 5 brackets and 5 hooks, per pipe. I use a standard 1/2 inch PVC coupler to connect each of the pipes together.
    Then, at the end of the season, I just unhook the entire 9.5 foot section and hang it on a rack in the ceiling of my garage, and leave the hooks in the eave for next year.
    BTW here is a picture of my super non fancy, no tech, not 3D printed, made from scrap plywood and 1/2 in dowel rod, drill fixture (the blue shrink tubing does not belong in the picture). Using a $20 yardsale table top drill press I have used this to drill over 3500 holes. The only issue I have had was, at first, I found that the line of holes would spiral on me, after a couple of pipes, I learned that I needed to to draw a straight line on the pipe end to end to follow when drilling to ensure my holes were not spiraling as I drilled.
  2. #22
    Nov 2019
    57
    Quote Originally Posted by Steve and Anthony View Post
    LOL! Old school ways work just fine! Gotta keep my eyes open for one of those yard sales ... I am clipping my pixels this year but will likely drill them next year when I settle on my pixel spacing.
