Results 1 to 4 of 4
Thread: espixelstick V3 programming help needed
    179
    Default espixelstick V3 programming help needed
    I've purchased some espixelstick V3's, but I haven't programmed them yet. I have V2s already and have used a USB-TTL to program them following these instructions: http://forkineye.com/wp-content/uplo...-and-Usage.pdf. However, for the V3's, it looks like there's a micro or mini USB connector instead? I'm not sure how to go about programming the V3s. Do I use this tool: https://github.com/forkineye/ESPSFlashTool ? Thank you!
    6,548
    Default Re: espixelstick V3 programming help needed
    Yes use the tool . The usb simplifies the connection .
    You may need to install a driver for the Wemos ch340 chip
    https://docs.wemos.cc/en/latest/ch340_driver.html
    Dec 2018
    NJ
    8
    Take a look at this video: https://youtu.be/FqGbrHAUyVQ
    179
    Perfect!! Exactly what I needed along with the Wemos link from angus40. And, it also helps if you have the right micro USB cable. Not all micro USB cables are created equally apparently. The third cable I tried worked. Thank you both for your help! Now I can get back to setting up lights and xLights programming....
    Quote Originally Posted by rmore View Post
