Results 1 to 5 of 5
Thread: graphics not in sync with music
    Jan 2010
    Mims, Fl
    800
    Default graphics not in sync with music
    Maybe not specifically a vixen question, but not sure where else to ask.
    My desk top that i am using to sequence does not seem to match up. for example, i have a pulse set up for each drum beat. I have the marks set, so the timing is correct, however, during each playback the lights are off a little different each time. I moved to the laptop i use at work to sequence and it keeps up just fine. I am only running 8gb memory on the desktop, laptop is 12gb. Desktop has AMD 4300 quad core processor 3.8 GHz. Desktop has NVidia GeForce GT710 graphics card.
    Any ideas or suggestions?
    Maryville, Illinois
    1,781
    Default Re: graphics not in sync with music
    You can share the profile on dropbox, Google Drive or something similar and I can take a look at it. Should be able to run a pretty big display with that hardware.
    Aug 2013
    Surprise, Az
    597
    Make sure you have your controllers turned off. They can really suck up the memory if they are on.
    Jan 2010
    Mims, Fl
    800
    Quote Originally Posted by Popo-B-Trippin View Post
    Ill check on that. If not, i will upload my profile. My dedktop is my "master profile" i copy the folders over to the laptop if i change anything.
    Jan 2010
    Mims, Fl
    800
    Always something coming up to distract me from the lights.
    i think i stopped/disabled the controllers, still lagging behind. Jeff i pm you like to the profile. took a few minutes to upload. I still need to clean up my folders, so you likely got lots of extra stuff.
