IIRC there are a few steps that are needed to accomplish this or it may have been Vixen to Xlights.
Anyways,I'm sure one of the other guys will chime in and give a more in depth answer. Good luck.
General help needed! I am not a computer wiz, I've down loaded the file from the sequencearmory, it is a xlight file. How do I get it to convert to a vixen 3 file so I can sequence? I've opened Vixen 3 selected tools>Import sequence> but when I search for the file I don't see it. But when I go to the download folder it's there. Please help.
Bill
(1)Falcon F16V3
(1) Kulp K32A-B
(1)Renard SS16
(1)Renard SS24
(1)EDM-LCD-CS-EP
(20)P10 Panels
WIKI
Become A Supporting Member
Falcon Christmas
Renard Controllers
I don't think there is an xLights to Vixen converter. And there is no xLights save as Vixen.
There is a basic vixen to xlights converter but nothing for xlights to vixen.
OK, thanks. I guess I have to sequence the old fashion way.![]()
You really have 3 options at this point and need to choose the best based on future effort.
1. Sequence yourself.
2. Find a vixen 3 source of free sequences.
3. Switch sequencers.
The latter only makes sense if the sequencing effort outweighs the effort to resetup your show.
Bump...still looking. If anyone has this as a Vixen 3 sequence, would you please share.
There are a bunch of sequences available in this thread... they are scattered throughout the thread.
http://doityourselfchristmas.com/for...ware-in-return
There is not a good way to do this, and I am not sure this even works any more or if the Vixen team would ever approve, but
In Xlights there is a Covert Tool and it will let you convert a xlights sequence file to other types, one of which is a Vixen 2.1 ".vix" file. Then in Vixen 3 you Open the the .VIX sequence and map it to your Vixen 3 display. The main problem here is that you have to have your display built in Vixen 2.1
this results in a lot of tiny effects. it should work.
