Results 1 to 10 of 16
Thread: Problems with a New Prop
    Chambersburg, PA
    954
    Default Problems with a New Prop - Solved!
    I added a small front porch to my house this summer and have built an "archway" consisting of 2 Boscoyo Chroma Poles of 300 pixels each and an 8x37 matrix in between. I have all 896 pixels being controlled from a single port on an ESPixelStick. When I test using the PixelStick effects everything works as expected, but when I take control from the RPi and FPP there seems to be lag when I run bars across the matrix. It changes 4 of the 8 pixels in a column, instead of the entire column at once. Also when I try to run Text across the matrix I am only seeing gibberish. The setup for the Matrix section of the archway is wired correctly in XLights and previews perfectly. I am running the Show network as Multicast.
    Am I pushing the limits of the ESPixelStick too far, should I add another controller into the prop? I have tried my test sequence at both 20 & 40 fps.
    Suggestions?
    2016 - No Display
    1,806
    Default Re: Problems with a New Prop
    Gibberish would indicate a mapping problem. I would fix that first and then see if you are having problems. I thought sporadic has indicated that 8266 based espixelstick would run 680 pixels reliably at 40 fps. You are defintely over that number but if the mapping is messed up, you might just be seeing fragments from the mapping.
    Chambersburg, PA
    954
    Gibberish would indicate a mapping problem. I would fix that first and then see if you are having problems. I thought sporadic has indicated that 8266 based espixelstick would ruin 680 pixels reliably at 40 fps. You are defintely over that number but if the mapping is messed up, you might just be seeing fragments from the mapping.
    I don't think the mapping is the issue, rather trying to run too many pixels. I will add another pixelstick to the prop and see how that works.
    2016 - No Display
    1,806
    You could test that pretty quick by configuring 680 pixels on the esp. The last 2xx should be dark and everything else should work correctly.
    4,928
    The ESPixelStick can drive in excess of 1000 pixels without an issue.
    Chambersburg, PA
    954
    I shortened the string down to 586 pixels and am still having the same issues. Whenever I run a test sequence on FPP for the Matix a simple Bars pattern is jerky and even simple TEXT does not display properly. I am using XLights and the actual prop matches the wiring views in XLights. I am running a horizontal 8x37 grid starting in the upper left corner of the matrix
    so I don't think it is a mapping issue. What else would you suggest?
    2016 - No Display
    Chambersburg, PA
    954
    bump
    2016 - No Display
    4,928
    Jerky sounds more like a network issue. Things not displaying right is usually a patching issue.
    Are you using unicast or multicast?
    Is your network quiet or noisy?
    Is the player connected to the wired interface on your AP?
    UK S80 postcode
    1,519
    Hi Tom, I think you can login to the ESPixelStick and check for dropped (or lost) packets, what does that say? I think if you power down it resets the value so you can do a couple of tests with the same setup.
    Chambersburg, PA
    954
    Hi Barnaby,
    Here is what I have on the stick at the moment:
    E1.31 Status
    Universe Range 50 to 53
    Total Packets 3237
    Sequence Errors 378
    Packet Errors 0
    Source IP 192.168.73.115
    I will do some more testing tomorrow.
    2016 - No Display
