Results 11 to 18 of 18
Thread: hp server psu
    Nov 2018
    Houston, Texas
    1,881
    Default Re: hp server psu
    I actually don't remember. I checked the controller I have left here and it's 12 volts.
    I will test one I got from you aswell
    Nov 2018
    Houston, Texas
    1,881
    11.77 on one I got from you
    Kansas City Missouri
    2,575
    If the supply is in a box the meter should read 12 volts. If I recall I had 2 supplies left. One of them should have a hole in the side. The other supply was slightly different and I didn't get around to finding which pot controlled the voltage.
    Nov 2018
    Houston, Texas
    1,881
    Yes it has the hole
    Nov 2018
    Houston, Texas
    1,881
    Default hp server psu
    From my understanding the voltage will drop like .2 volts once a load is applied so at 12.07 no load I should be good without an adjustment. But im just going off what Iíve watched and read.
    2,575
    Yes it has the hole
    Use a non-metallic screwdriver to make a voltage adjustment with this one.
    Delaware, OH
    4,411
    Remember, that the power you read at the supply may not be the power once it gets to the pixels due to the DC voltage drop on the wire you use to connect.
    Nov 2018
    Houston, Texas
    1,881
    Thank you
