Results 11 to 20 of 24
Thread: V-FMT212R Transmitter
    6,466
    Default Re: V-FMT212R Transmitter
    Quote Originally Posted by clpd7 View Post
    Angus 40 I was able to extract your file and save it but still not able to transmit over the radio. I had to change the frequency since 90.1 is a local station here. Is there suppose to be a cable plugged into the Aux in? Thanks.... Larry
    Hi
    There are only 2 connections to this transmitter usb for input and the antenna .
    Once you have HiFi-FMT open and your usb connected , right click on the Speaker Icon in Windows and select Playback devices
    You should see in the list { Speaker VASTint/FMT - 212 Transmitter }
    You will need to select it and Set it to Default Device !
    Chambersburg, PA
    770
    I just looked at my FMT-212 and there is also an Aux In. I go PI>Sound Blaster Play 3 via USB>FMT-212 via 3.5mm cable. I power the FMT-212 via the USB port. The image below shows my Control Center which also connects to my Ubiquiti Loco M2 to broadcast to my show. All of my controllers are wireless this year.
    2016 - No Display
    6,466
    Wow . my apologies , I did not realize that there were variants of this model
    I purchased this as a backup back when they were becoming obsolete I believe from this forum or DiyLedExpress .
    Only used 1 season while waiting for a replacement Transmitter to arrive .
    Jul 2020
    7
    Angus 40 thanks for helping a guys that has no clue what he is doing. I have done all of this. It's hooked up to my computer. Now what do I use to broadcast it across the radio in the car. I feel this is a dumb question but I've always been told a dumb question is one never asked. i have plugged up a set of headphones with a mic but still no luck. Thanks again....Larry
    Chambersburg, PA
    770
    clpd7,
    Just asking because the info is not in this thread, what kind of antenna do you have connected to the transmitter, and what freq are you trying to broadcast?
    2016 - No Display
    6,466
    As a test , connect your Vast to a usb port and open HiFi FMT App
    Click File /Load Config then load this .ini file below ->
    Then open your sound -> playback devices and select your Vast as the image shows below
    once done play some audio and listen to it on your stereo @ 90.1 fm
    Attached Files Attached Files
    6,466
    Is the aux required ?
    Chambersburg, PA
    770
    I have found the Sound Blaster greatly improves the audio quality of the system, and output from the SB uses a 3.5mm connection. There is an Excellent Video from the Virtual Christmas Summit on Transmitting Your Audio on YouTube. I would recommend anyone who would like to improve their audio quality should watch.
    2016 - No Display
  9. #19
    6,466
    I see , being that you are using an external sound device it makes sense .
    I would think that your Vast would work solely by usb directly to a PC also .
  10. #20
    Chambersburg, PA
    770
    I am sure it would, but I have been convinced that this is a better way for me to go.
    2016 - No Display
