Results 1 to 10 of 10
Thread: How to reduce voltage from 12.3 volts to 11.8 volts?
    Jan 2013
    Henderson, Nevada
    830
    Default How to reduce voltage from 12.3 volts to 11.8 volts?
    I have a server power supply that is running at 12.3 volts. The lowest I can adjust it down to is 12.1 volts. Is there a way to reduce the 12.3 volts to 11.8 volts. I see most buck converters need 1.5 volts more coming in than going out. I need to reduce the voltage to 11.8 volts to supply some of my older pixels. The pixels don't operate correctly with voltage any higher than 11.8. Any ideas?
    Kansas City Missouri
    2,487
    Default Re: How to reduce voltage from 12.3 volts to 11.8 volts?
    Quote Originally Posted by kenoman742 View Post
    My server supply was 12.2 and got it down to 11.7.
    Jan 2013
    Henderson, Nevada
    830
    How did you get it down to 12.7? The pot adjustment on the power supply board will only get me to 12.1 then it jumps back up to 12.5. It appears I can only adjust +/- 0.25 volts.
    2,487
    The pot adjustment on 2 of mine got it down. The other one actually went down to 11.8. Could be the brand of power supply.
    Colorado Springs
    3,783
    Hmm, a resistor in series??????
    Nov 2015
    The Netherlands
    80
    a silicon diode in series will drop 0,7V, Schottky diodes 0,15 to 0,4 V
    Errors for fun only.
    4,299
    A resistor voltage drop is dependent on the current going through the resistor and would be changing all the time. A diode voltage drop is inverse current dependent and the curve is VERY steep so you wont notice it in our application. A high current diode should do what you need.
    Jan 2013
    Henderson, Nevada
    830
    Thanks to everyone for the suggestions. I'll just have to experiment to find a solution. As a last resort I do have a generic 12v power supply I can use that is already dialed down to 11.8 volts. I am just trying to power my display with 2 - 1200 watt server power supplies. Thanks again for all suggestions.
    Ken
    Oct 2012
    Seal Beach, CA
    51
    That diode will be a nice little heater too.
    4,299
    Yes it needs to dissipate some heat. 0.7v * 60a = 42w. That is a light bulb.
