Thread: Vertical runs on brick house
    Nov 2018
    Houston, Texas
    1,390
    Default Vertical runs on brick house
    Wondering how others are doing the vertical pixel runs on brick corners ?
    7,969
    Default Re: Vertical runs on brick house
    Mine are in Boscoyo strips. I have cup hooks in the eave that they hang from and I attach the bottom to a stake in the ground. They donít actually touch the brick at all.
    Jul 2012
    Novi, MI
    398
    Agree with Jon's approach. Stainless steel hooks in the soffit and something at the bottom to keep the strip taut. I use bungie cords.
    Nov 2018
    Houston, Texas
    1,390
    Was trying to come up with away to mount my set up as I use pvc and still working on it but it does work so far needs tweaking
    Dec 2018
    52
    I used the Holiday coro clips and drilled 1/2 pvc for the pixels
    Nov 2018
    Houston, Texas
    1,390
    Quote Originally Posted by cjrobin27 View Post
    Did you drill into your brick to mount ?
    Nov 2018
    Houston, Texas
    1,390
    Think I got it worked out with no drilling of holes anywhere or hot glue .
    1,526
    Could do the same thing that Jon said, Hook in the soffit to hang the PVC from and something to secure it to the ground to keep it straight
    Mar 2016
    CA
    258
    Interesting question, I'm trying to figure out a few things related where I don't have mounts, and I'm not drilling into the house.
    I just did a proof of concept with Holiday Coro's ribbon mounts. I used clear silicone on a horizontal run on stone to temporarily attach the small clips this snaps into. You could easily mount this on 3/4" square molding stick to make larger continuous mounts. And silicone the wood to the brick. I don't think it would take many spots to hold it vertical if the piece rests on something at the bottom.
    http://www.holidaycoro.com/12mm-Stri...lder-p/766.htm
    I read an article that says hot glue gun works really well, although my biggest mounting challenge is stucco over styrofoam, and I have to do a test to see if the glue will rip off the stucco. I'm going to try silicon also.
    youtu.be/nBL9qYPaXwQ
