Results 1 to 10 of 11
Thread: Renard not passing data
    Oct 2019
    9
    Default Renard not passing data
    I assembled my two SS24's back in January of 2020. I tried testing them out once connecting them. Since there are two, I'll call one controller A, and the other controller B. Basically, both had worked fine on their own when given power and a data source, but I had never successfully linked them together since I attempted to, then controller B (Attached to controller A) started flickering and then went completely dark while I was running a test sequence. After that, I couldn't get controller B to receive data. I only goth them both working when I switched the two controllers (Where controller A is receiving data from controller B,) and they worked fine. I've come to the conclusion that something isn't working on the output of controller A. I checked all my solder pads and they were fine, there was also no bridging. If it's important, the PIC's are programmed with the DMX firmware. Does anybody know what's happening with controller the output on controller A?
    1,545
    Default Re: Renard not passing data
    Pictures of your board might be helpful.
    Did you flash them with the same software or did you change the addresses for each one?
    Oct 2019
    9
    I flashed all 6 of the total PICs with the DMX firmware with a start adress of 1
    6,702
    You may want to have a look at U4 & U5 on controller A for issues. As a simple test you could swap the ic's with controller B
    then reconnect the daisy as A - B to see if they are faulty .
    Holland, Manitoba
    519
    Had that issue once with 2 SS8's. Went through the trouble shooting guide testing and checking everything and couldn't find it. Ended up it was a bad RJ45 plug on the output of the board. Easiest thing to replace, but of course it was the last thing I checked.
    There is an excellent troubleshooting guide in the wiki.
    Good luck, and don't forget to post when you find the problem. Might help someone else in the future.
    Rob
    1,556
    Look down inside the RJ45 jack, I had one where the Wires were crossed. You can fix that, uncross them w/ a small flat blade screw driver, just not sure if you would need to remove the plug first or not.
    Quote Originally Posted by bud29 View Post
    Rob
    Nov 2020
    US, VA
    7
    Rob
    Thank you! I just had this issue and switched out the RJ45 plug from J2 to J1. That fixed my issue.
    Holland, Manitoba
    519
    No problemo, nice to know it helped someone.
    Nov 2020
    US, VA
    7
    Well oddly it worked yesterday, but no longer works today. So I'm not sure what's going on now
    Apr 2011
    Redding Ca
    346
    Most times I have found that flowing the solder around the plug in and out will fix this.
