Page 2 of 8 FirstFirst 1234 ... LastLast
Results 11 to 20 of 74
Thread: Creality build.
    Nov 2018
    Houston, Texas
    2,077
    Default Re: Creality build.
    So, what? You open the supply and replace the fan with the one from noctura?
    Jeff
    Yes but there are 2 fans and each is diffferent so have to make sure to get it correct
    Kansas City Missouri
    2,748
    Thereís a fan from noctura that everyone Iíve asked says is way quieter than the stock fans
    Noctua NF-A4x10 FLX, Premium Quiet Fan, 3-Pin (40x10mm, Brown) https://www.amazon.com/dp/B009NQLT0M..._63XMEb4EJVV2V
    Have not ordered yet but definitely will at some point.
    Depends if it will fit inside power supply.
    Nov 2018
    Houston, Texas
    2,077
    Ender 3 pro uses 24vol power and only has 1 pin set for fan the noctura are supposed to come as kit to splice into existing wires was told it comes with all connections in box
    Nov 2018
    Houston, Texas
    2,077
    There are many videos on you tube that show this just check it out as an alternative
    Nov 2018
    Houston, Texas
    2,077
    Canít get it to share link so here is one
    Nov 2018
    Houston, Texas
    2,077
    Another recommendation is learn the machine and everything you can prior to tinkering with movement upgrades as in old saying if it ainít broke donít fix it
    And use a square to level your axis you want it dead on
    New Jersey
    1,402
    Thanks, viewing now.
    Jeff
    2,748
    It's possible the ender fan is regulated 12 volts. Won't know until I take it apart.
    Nov 2018
    Houston, Texas
    2,077
    Jeff
    Just upgrade my fan duct and seems to work pretty good
    Nov 2018
    Houston, Texas
    2,077
    From what i understand and videos I saw itís 24 volt fan it was listed in a link on one of the videos . The older models and original Ender 3 are 12 volt
