Page 1 of 8 123 ... LastLast
Results 1 to 10 of 74
Thread: Creality build.
    New Jersey
    1,400
    Default Creality build.
    Ender 3 build before and after. Then the phone rang, and I have to leave now. Power up later.
    Nov 2018
    Houston, Texas
    2,075
    Default Re: Creality build.
    Well at least itís started good luck!
    Kansas City Missouri
    2,748
    I just got one a week ago. I installed dampers for 2 of the steppers. You can't hear mine running except for the power supply fan.
    Nov 2018
    Houston, Texas
    2,075
    Thereís a fan to fix that aswell
    New Jersey
    1,400
    OK, so I’m on standby for a little while. I just leveled the bed. How much tension would you expect the paper to have as you move it under the nozzle? I made it so it was scraping the paper, but had very little tension. More, or less than that? They don’t make it very clear in their video. And BTW, it’s really quiet from the start.
    Jeff
    Nov 2018
    Houston, Texas
    2,075
    OK, so Iím on standby for a little while. I just leveled the bed. How much tension would you expect the paper to have as you move it under the nozzle? I made it so it was scraping the paper, but had very little tension. More, or less than that? They donít make it very clear in their video. And BTW, itís really quiet from the start.
    Jeff
    So I start there then ten level test off Thingiverse and adjust from there
    2,748
    Will be kind of hard to baffle the fan noise.
    Nov 2018
    Houston, Texas
    2,075
    Thereís a fan from noctura that everyone Iíve asked says is way quieter than the stock fans
    Noctua NF-A4x10 FLX, Premium Quiet Fan, 3-Pin (40x10mm, Brown) https://www.amazon.com/dp/B009NQLT0M..._63XMEb4EJVV2V
    Have not ordered yet but definitely will at some point.
    New Jersey
    1,400
    Well, I’m not gonna get anything printed today. The filament I ordered won’t be here until next week sometime. But at least it’s set up. Do you have a link to the test on thingiverse?
    Jeff
    New Jersey
    1,400
    There’s a fan from noctura that everyone I’ve asked says is way quieter than the stock fans.
    So, what? You open the supply and replace the fan with the one from noctura?
    Jeff
