Thread: FPP v3.6.2 with F16V3 v 2.01 channel offset
    Saint George, UT
    92
    Default FPP v3.6.2 with F16V3 v 2.01 channel offset
    Before I update my firmware on my F16V3 I was wondering if anyone has had an issue with their port mapping from the FPP to the Falcon F16. When I go into test mode on the FPP my channels don't map correctly. The first port on the F16 is channel 1-300 with 100 pixels and a Univ size of 300. The FPP also has the size as 300. The F16 is configured with universe 100-124. When I test from channel 1-300 I don't get anything with pixels on port 1. If I test 301-600 they light. When I put them on port 2 they only light up with 901-1200 instead of 301-600.
    Is this because I'm using old firmware on the F16 with new firmware on the FPP?
    Doug
    Jan 2010
    507
    Default Re: FPP v3.6.2 with F16V3 v 2.01 channel offset
    I would do the update (you're going to want to regardless) then test.
    Saint George, UT
    92
    Thanks, I updated it and it fixed the problem.
