Results 1 to 10 of 20
Thread: I need a show router...
    New Jersey
    1,341
    Default I need a show router...
    Any suggestions on a decent inexpensive wireless router? I don't want to spend more than $100. Need it to work well with RPP and as a show wifi mainly to play happy with ESPixel. I'm gonna put it in a box close to the house. Nothing wireless will be further than 60' from it.
    Jeff
    4,254
    Default Re: I need a show router...
    ubiquity nano running ddwrt
    Nov 2018
    Houston, Texas
    1,390
    Jeff
    I donít know much about the RPP you speak of but I got this and the range is amazing Ubiquiti NanoStation locoM2 2.4GHz Indoor/Outdoor airMax 8dBi CPE https://www.amazon.com/dp/B00DCNRTAG..._BU5EEbG555B0Y
    Ubiquiti Networks Networks Networks Router (ER-X), Black https://www.amazon.com/dp/B0144R449W..._gX5EEbCJ4Q7W6
    And this
    New Jersey
    1,341
    OK. Wilmar, thank you for the link. Martin, I see in the DD-WRT Router DB, the part William linked is listed as "Nanostation M2 Loco" Is that what I need? If so, I'll get it on order.
    Thank you both!
    Jeff
    New Jersey
    1,341
    I don’t know much about the RPP you speak of...
    I meant to say FPP. Falcon Player for Raspberry Pi.
    Jeff
    Nov 2018
    Houston, Texas
    1,390
    Jeff
    Ok I have a pi zero set up with FPP that tested fine with my nano stuff but I donít know the dwrt stuff .
    4,254
    Thank you both!
    Jeff
    Yes that is a good choice.
    4,254
    The DD-WRT software allows significant configuration flexibility which has proven useful when tuning a show to work over WiFi.
    New Jersey
    1,341
    On order. I see the activation for the DD-WRT is $22. Still well under $100. Thank you for the help. I was looking at this thing as a bridge. I trenched and ran 4" flex, then fiber to my shed to get the network out there. This would've been a bit less labor... But I also wouldn't have water out there, and an air line in from the compressor.
    Jeff
    New Jersey
    1,341
    But it's not totally necessary if I'm only running an half dozen wireless devices? Less than a single universe total.
    Jeff
