Results 11 to 20 of 27
Thread: Trouble communicating Vixen to E1.31 bridge to DMX
    1,283
    Default Re: Trouble communicating Vixen to E1.31 bridge to DMX
    This bridge appears to be a multicast only device for e1.31 data. The only thing the ip address is good for is setting the parameters. I can't think of what you are missing in the Vixen config. You got the lights to work using xLights so all the physical and logical connections would appear to be working. I don't see any explanation for the leds on the bridge while it is running. Do they change when you start up Vixen?
    Jan 2010
    507
    Just out of curiosity, how do you know it doesn't work? Are you running a sequence in Vixen? Using the test function in Vixen?
    Dec 2019
    13
    Unicast seems to definately have the problem I've tried focusing everything on getting unicast to work but no luck with Vixen or Xlights. I've followed the procedure for setup with PC giving myself a static address of 192.168.1.5, with the E1.31 address to 192.168.1.205 (I changed the E1.31 end IP from 206 to 205) both subnets match 255.255.255.0 and gateways match. My DMX device has no dipswitches it is capable of lighting up 8 separate Dumb Led strips it is supposed to be able to detect the hardware changes. Has anyone had any troubles with Network cards or had to get extra protocols to install. I feel like some small detail is missed somewhere. Here are my setups again.
    E1.31 device setup.jpgPC Setup.pngUnicast Setup.jpg41wYBm--u8L._AC_.jpg81fP4eS5C3L._AC_SL1500_.jpg
    Jan 2010
    507
    you have the bridge ip set to .205 and Vixen pointing to .206 or did I read your post wrong?
    4,254
    How many interfaces are active on your PC and if more than one, please show us the configuration for the other interfaces. Please show interface configs by opening a command prompt window in admin mode and typing: ipconfig /all
    You should get a result like the attached image.
    Dec 2019
    13
    hi gassy yes i had wrong picture of my unicast this is the correct picture
    Martin here is my networks from ipconfig
    C:\Users\irvin>ipconfig /all
    Windows IP Configuration
    Host Name . . . . . . . . . . . . : DadTop
    Primary Dns Suffix . . . . . . . :
    Node Type . . . . . . . . . . . . : Hybrid
    IP Routing Enabled. . . . . . . . : No
    WINS Proxy Enabled. . . . . . . . : No
    DNS Suffix Search List. . . . . . : hsd1.mi.comcast.net
    Ethernet adapter Multicast Vixen:
    Media State . . . . . . . . . . . : Media disconnected
    Connection-specific DNS Suffix . :
    Description . . . . . . . . . . . : Realtek PCIe FE Family Controller
    Physical Address. . . . . . . . . : 74-86-7A-17-1D-6A
    DHCP Enabled. . . . . . . . . . . : No
    Autoconfiguration Enabled . . . . : Yes
    Wireless LAN adapter Local Area Connection* 1:
    Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
    Physical Address. . . . . . . . . : 9E-2A-70-D1-70-1D
    DHCP Enabled. . . . . . . . . . . : Yes
    Wireless LAN adapter Local Area Connection* 2:
    Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #2
    Physical Address. . . . . . . . . : 9E-2A-70-D1-78-1D
    Ethernet adapter Ethernet 2:
    Description . . . . . . . . . . . : TAP-Windows Adapter V9
    Physical Address. . . . . . . . . : 00-FF-BF-55-45-22
    Wireless LAN adapter Wi-Fi:
    Connection-specific DNS Suffix . : hsd1.mi.comcast.net
    Description . . . . . . . . . . . : Dell Wireless 1704 802.11b/g/n (2.4GHz)
    Physical Address. . . . . . . . . : 9C-2A-70-D1-70-1D
    IPv6 Address. . . . . . . . . . . : 2601:407:4100:b180::d69a(Preferred)
    Lease Obtained. . . . . . . . . . : Wednesday, March 25, 2020 10:27:51 AM
    Lease Expires . . . . . . . . . . : Tuesday, March 31, 2020 11:31:57 PM
    Link-local IPv6 Address . . . . . : fe80::4cbc:d4f9:a594:30f7%20(Preferred)
    IPv4 Address. . . . . . . . . . . : 10.0.0.10(Preferred)
    Subnet Mask . . . . . . . . . . . : 255.255.255.0
    Lease Obtained. . . . . . . . . . : Wednesday, March 25, 2020 10:27:33 AM
    Lease Expires . . . . . . . . . . : Wednesday, April 1, 2020 4:31:55 PM
    Default Gateway . . . . . . . . . : 10.0.0.1
    DHCP Server . . . . . . . . . . . : 10.0.0.1
    DHCPv6 IAID . . . . . . . . . . . : 94120560
    DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-25-83-71-9A-74-86-7A-17-1D-6A
    DNS Servers . . . . . . . . . . . : 2001:558:feed::1
    2001:558:feed::2
    75.75.75.75
    75.75.76.76
    NetBIOS over Tcpip. . . . . . . . : Enabled
    C:\Users\irvin>
    Dec 2019
    13
    This is my networks ipconfig when e1.31 is connected and with wifi disabled
    Microsoft Windows [Version 10.0.18362.720]
    (c) 2019 Microsoft Corporation. All rights reserved.
    Link-local IPv6 Address . . . . . : fe80::4194:3b38:771c:c84a%5(Preferred)
    IPv4 Address. . . . . . . . . . . : 192.168.1.5(Preferred)
    Default Gateway . . . . . . . . . : 192.168.1.1
    DHCPv6 IAID . . . . . . . . . . . : 91522682
    DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
    fec0:0:0:ffff::2%1
    fec0:0:0:ffff::3%1
    C:\Users\irvin>
    Jan 2010
    507
    You haven't mentioned how you're testing in Vixen to know that the controllers are not lighting up your lights.
    1,283
    Quote Originally Posted by gassy View Post
    With multicast, it doesn't matter. The bridge is listening for multcast universes not looking to connect with the PC.
    Jan 2010
    507
    That is correct...the comment was made when another member was trying to help him connect with unicast rather than multicast.
