Results 1 to 7 of 7
Thread: Window help
    Nov 2018
    Houston, Texas
    1,482
    Default Window help
    I was playing with effects on my newly pixeled window frames and as suggested I ran lights clockwise starting at bottom left . When I ran a chase sequence it did not look right as it went up right down left then to next window the same then the next . The part that didnít look right was the final left . Didnít seem to be fluid movement across the three windows or am I doing something wrong .
    Is there any special grouping like horizontals and verticals
    Hope I explained myself correctly.
    4,299
    Default Re: Window help
    You will need to tell people which sequencer you used and which controller (I think I can guess that tho).
    Nov 2018
    Houston, Texas
    1,482
    Yea vixen 3 with espixel pop sorry
    4,299
    Can you post a video?
    Nov 2018
    Houston, Texas
    1,482
    I put em in attic but picture three windows side by side ,chase starts from far left and goes up then goes right across top then down then left that left makes it look funny before going to the next window which is on the right ... if I explained it right
    Aug 2013
    Surprise, Az
    590
    The chase effect will go in light order, meaning, the way it was wired. I'm guessing that is what it is doing here. If you're trying to get it to wipe from left to right across the entire window, try using the wipe effect. It is a location based effect so, if I'm understanding what you're trying to do, that should give you what you are looking for. But there's also a good chance I'm not understanding what you're trying for...
    Nov 2018
    Houston, Texas
    1,482
    Quote Originally Posted by Popo-B-Trippin View Post
    Yes wipe effect sounds right thank you
