Thread: Starting point
    Nov 2018
    Houston, Texas
    1,390
    Default Starting point
    May sound dumb but when stringing pixels around windows and such , is there a recommended starting point for number 1 pixel in each window ?
    Like bottom left corner going clockwise or top right corner counterclockwise or does it even mater where you start?
    Kansas City Missouri
    2,466
    Default Re: Starting point
    I would go bottom left clockwise. The first pixel is closer to your connections.
    Nov 2018
    Houston, Texas
    1,390
    Great thank you
    Nov 2014
    Close to Hillsboro, OR
    508
    When you draw your poly line in xLights, and then end it, xLights allows you to determine whether the green square or the blue square is the starting point. If you are using Vixen, I would imagine it does the same thing. But, yes, bottom left or bottom right would be your best choice so you have less wires visible.
    I have included a capture of my layout in xLights to show you an example.
    Nov 2018
    Houston, Texas
    1,390
    Thanks so much
