Page 9 of 41 FirstFirst ... 789101119 ... LastLast
Results 81 to 90 of 405
Thread: Rbl ?
  1. #81
    Kansas City Missouri
    2,464
    Default Re: Rbl ?
    Ok so I scaled it down to fit in 120x120 box and hereís what your left with at that size unless Iím missing something...
    Only will have room for 1 bullet
    The hole in bottom is 12.1mm
    This is keeping eall pieces uniform to scale .
    Yup, can only print one at a time. If these are to be hung how is that accomplished? I would consider using 1/4" "J" hook.
  2. #82
    Nov 2018
    Houston, Texas
    1,383
    Default Re: Rbl ?
    Ah let me see what I can come up with forgot about hook
  3. #83
    2,464
    Default Re: Rbl ?
    A printed hook may not be strong enough especially in the wind. I accidently dropped one of mine and the hook broke. I ended up printing a round insert which I screwed into the top and used a j hook for hanging. If dropped it won't break.
  4. #84
    Nov 2018
    Houston, Texas
    1,383
    Default Re: Rbl ?
    Ok cool
  5. #85
    Nov 2018
    Houston, Texas
    1,383
    Default Re: Rbl ?
    May be able to do what Iím doing with mine
  6. #86
    2,464
    Default Re: Rbl ?
    I just ordered an Ender 3 Pro.
  7. #87
    Nov 2018
    Houston, Texas
    1,383
    Default Re: Rbl ?
    Ok got the base into a workable one piece design , printed with no supports so had to some clean up ,so for 5 bullet style pixels Iíll probably be using this version . For the carnival style lights Iíll have to do something different as they wonít fit in the mini RBL . Ran out of black fillament so had to go all white for now for testing but few minor changes to do today and should be ready for this version . I think these will fit my needs better than the big ones . Feel free to share thoughts as I will share files once completed should be this evening.
  8. #88
    4,250
    Default Re: Rbl ?
    Very Nice Job.
  9. #89
    Nov 2018
    Houston, Texas
    1,383
    Default Re: Rbl ?
    Very Nice Job.
    Thank you
  10. #90
    New Jersey
    1,341
    Default Re: Rbl ?
    William,
    My thought? Wow! That thing is beautiful! If my printer makes it through the C-19 world shut down, I’d like to print one just to see if it’s something I can add to my show. I said I was gonna pick your brain... what tips, filament and source did you use/prefer? I didn’t understand your explanation of how much filament it took to make.
    Thank you so much for sharing!
    Jeff
