Page 45 of 46 FirstFirst ... 3543444546 LastLast
Results 441 to 450 of 457
Thread: Rbl ?
  1. #441
    Nov 2019
    Waukee Iowa USA
    15
    Default Re: Rbl ?
    I think I now know why my threads are tight. I have been over extruding. I did a cube test and I changed my extruder flow down to 87%. From 100%. New prints won't be done till late tonight. 0.8 mm nozzle.
    Sent from my SM-N950U using Tapatalk
  2. #442
    Nov 2018
    Houston, Texas
    1,691
    Default Re: Rbl ?
    Quote Originally Posted by sam-tip View Post
    Good luck
  3. #443
    Nov 2019
    Waukee Iowa USA
    15
    Default Re: Rbl ?
    Question
    How thick are you making the walls of the RBLs. Just printed one bulb at 3 layers at 2.4 mm. Now trying 4 layers at 3.2 mm.
    Cura says my print time is down to 2 hours 52 minutes. The new prints did go together a little better but the shroud of the base still does not meet the bulb.
    Doug (samtip)
    PS I think I sent you a PM but can't see where I did.
  4. #444
    Nov 2018
    Houston, Texas
    1,691
    Default Re: Rbl ?
    I use .32 layer height
  5. #445
    Nov 2018
    Houston, Texas
    1,691
    Default Re: Rbl ?
  6. #446
    Nov 2018
    Houston, Texas
    1,691
    Default Re: Rbl ?
    Question
    Doug (samtip)
    Basically I just use draft quality and tweet stuff like infill spread and adherence.
  7. #447
    Nov 2018
    Houston, Texas
    1,691
    Default Re: Rbl ?
    Question
    Doug (samtip)
    Started another print of bulb using same file I sent you for a test petg I wouldnít rush the print and I also donít use cooling for petg not sure if that makes a difference
  8. #448
    Nov 2019
    Waukee Iowa USA
    15
    Default Re: Rbl ?
    Have you thought about using adaptive layers for the bulb? Where cura changes the layer height where the threads are located? It will take longer to print but you get better detail at threads and less detail on the bulb.
    Download Fusion 360 yesterday and watched many YouTube videos. I think I am figuring out how you made the RBL stl. My first two models.
  9. #449
    Nov 2018
    Houston, Texas
    1,691
    Default Re: Rbl ?
    Looks good
  10. #450
    Ontario, Canada
    2,149
    Default Re: Rbl ?
    If these are the Home Depot RBL's, they manufactured two batches, one is 2mm smaller at the thread. Ive posted both versions on Thingiverse
    Cheers!
    Steve
    Learn 1 new thing everyday.
    "AURBO" -- Aurora Borealis
    My weather today
