Page 44 of 46 FirstFirst ... 344243444546 LastLast
Results 431 to 440 of 457
Thread: Rbl ?
  1. #431
    Nov 2018
    Houston, Texas
    1,705
    Default Re: Rbl ?
    Quote Originally Posted by sam-tip View Post
    How well should the bulb and socket screw together. I am getting about 1/4 turn putting them together. Should I play with scaling size to make them screw together better?
    Doug
    Did you change scale on anything you printed ?
  2. #432
    Nov 2018
    Houston, Texas
    1,705
    Default Re: Rbl ?
    Doug
    On my short thread bulbs I printed with pla and my base I printed in petg I get almost exactly 1 complete revolution .
  3. #433
    Nov 2019
    Waukee Iowa USA
    15
    Default Re: Rbl ?
    I just pulled them into Cura 4.6 and sliced. Doesn't PLA shrink a little more than PETG after printing. But by how much? Trying clear PETG now on Bulbs. My first batch of PETG was a pain to print with. The clear looks better.
  4. #434
    Nov 2018
    Houston, Texas
    1,705
    Default Re: Rbl ?
    I printed a couple in petg of the bulbs and I had to trim off the starting point of the thread a little if I remember it was a little snug .
  5. #435
    Anchorage, AK
    363
    Default Re: Rbl ?
    My first print would not start the thread. Not sure of the issue just yet. 2 different bases, one bulb in PLA, the bulb would not thread into either base. I dont want to get too aggressive with sanding/fileling until I try another bulb.
    The first print kinda messed up the top on the "no hole design". I might try the larger nozzel on the "hole" design to see if it improves the fill on the bulb, as I saw one hole all the way through. It also leaves a line all the way up one side as the print switches direction at that point, maybe that is normal? Not a big issue if I put it at the back.
    Any ideas?
  6. #436
    Nov 2018
    Houston, Texas
    1,705
    Default Re: Rbl ?
    Any ideas?
    Zseam alignment setting will change that you can set to random but my printer didnít like that so Iím fine with the line . As for threads only ones I noticed were tight was petg . I have printed at this point about 20 for myself and 48 that were sold and another 20 because a shipment was almost a month late and all printed somewhat a bit diff depending on printer and settings but all worked .
    What I found was if the first layer is layer down too squished it made for a tight fit which is why I had to trim a bit off the first thread. If this is your issue you may be able to scale down like .5 or 1 percent to help with the fit .
  7. #437
    Nov 2018
    Houston, Texas
    1,705
    Default Re: Rbl ?
    I also have about 20 or so extra bases made from black petg laying around .
  8. #438
    Anchorage, AK
    363
    Default Re: Rbl ?
    Zseam alignment setting will change that you can set to random but my printer didn’t like that so I’m fine with the line . As for threads only ones I noticed were tight was petg . I have printed at this point about 20 for myself and 48 that were sold and another 20 because a shipment was almost a month late and all printed somewhat a bit diff depending on printer and settings but all worked .
    I dont mind the seam, will just hide it on back side. I will try trimming the first thread a tad, but that will have to wait, as I am flying out on a work trip tomorrow morning for 1-2 weeks. I will let you know what I find. Thanks for the prompt response.
  9. #439
    Nov 2019
    Waukee Iowa USA
    15
    Default Re: Rbl ?
    I tried grinding some off. Didn't help much. I also tried increasing base 1.5% in x y and z. Small improvement. Today will try increasing just the x and y.
    Printed three bulbs at once last night. Could have done more but did not have enough filament on roll.
  10. #440
    Nov 2018
    Houston, Texas
    1,705
    Default Re: Rbl ?
    I can send you another file to try if you like not sure it would work better or worse or same
