Page 36 of 46 FirstFirst ... 263435363738 ... LastLast
Results 351 to 360 of 457
Thread: Rbl ?
  1. #351
    821
    Default Re: Rbl ?
    How’s the prints with petg working out ?
    SLow but making progress with things. Still waiting on a roll of white PETG to try a globe. I have to do some other things for a couple of days but will work on it when I can.
    I would be interested in the gcode you have come up with as well if possible? Always helps to be able to compare different settings for things. Guess I will have to get a .8 nozzle to try as well for better speed.
  2. #352
    821
    Default Re: Rbl ?
    I got pack of 20 from amazon for like 8 bucks some work some donít but for 8 bucks if I get half to work Iím good but thatís me Iím cheap for most things if it makes sense . Some pay 10 or more each nozzle
    Are you using brass nozzles or steel? I have been looking at getting some steel ones although I am still using the stock brass one so far.
  3. #353
    Nov 2018
    Houston, Texas
    1,705
    Default Re: Rbl ?
    Quote Originally Posted by beeiilll View Post
    Brass
  4. #354
    Nov 2018
    Houston, Texas
    1,705
    Default Re: Rbl ?
    Results are this 5 hrs 48 min and can you tell which one took 17 hrs and which took 6 ?
  5. #355
    Nov 2018
    Houston, Texas
    1,705
    Default Re: Rbl ?
  6. #356
    Nov 2018
    Houston, Texas
    1,705
    Default Re: Rbl ?
    I wanted your gcode files. Compare them to the settings I use.
    Msg me your email and Iíll sendd you the new code for the .8 mm nozzle fast set up .
  7. #357
    Nov 2018
    Houston, Texas
    1,705
    Default Re: Rbl ?
    Got the print times down to :
    Unsupervised print : 4.5 hours for bulb 4 hours for base
    Supervised print : 3 - 4 hours for bulb
    (By supervised I have found I can almost double the speed at certain points in the print and slow back down at the tip )
    And they are actually turning out a bit better than the oringinal 17 and 8 hour prints previously done .
    That being said I made many of these in trying to get the print times down and quality up so If anyone is interested.
  8. #358
    821
    Default Re: Rbl ?
    Well, I finally got around to trying out PETG for these globes. Seems to have come out quite nicely actually. I used MaterHackers White PETG filament running at 240 on the head and 80 degrees on the bed. This was at 80 for speed using a .04 nozzle. I have a .08 nozzle that I will have to try and see how fast I can get one of these printed. This one took just over 12 hours.
  9. #359
    Nov 2018
    Houston, Texas
    1,705
    Default Re: Rbl ?
    Nice how does petg work with light as for transparency?
  10. #360
    Nov 2018
    Houston, Texas
    1,705
    Default Re: Rbl ?
    Fastest I printed so far with .8 is 3 hours 10 min.
    Just installed 1mm nozzle and going to push the limits
