Page 21 of 41 FirstFirst ... 11192021222331 ... LastLast
Results 201 to 210 of 405
Thread: Rbl ?
  1. #201
    Nov 2018
    Houston, Texas
    1,383
    Default Re: Rbl ?
    I give up I canít get dam things to work and burnt out 2 pixel pops already Iíll keep my bullets
  2. #202
    6,368
    Default Re: Rbl ?
    What method are you using Serial ? Are these dumb r,g,b ?
    You will likely need a max485.
    For ESPixelStick Firmware . if while you were installing and you selected Pixel then you can only control WS281* or GECE type pixels .
    else
    If you select Serial , you have an opportunity to use Renard or Dmx which is favorable for dumb r,g,b using the very very limited gpio of the esp-01
  3. #203
    Nov 2018
    Houston, Texas
    1,383
    Default Re: Rbl ?
    else
  4. #204
    6,368
    Default Re: Rbl ?
    Ah , 3 leds per pixel So you are using 6 Ws2811 pixels . Should be simple enough.
    Make sure you connect to DI for data line and V+ V- to 12v .
  5. #205
    Nov 2018
    Houston, Texas
    1,383
    Default Re: Rbl ?
    Make sure you connect to DI for data and V+ V- .
    Yep triple checked over and over arrow direction network connection all was good then the pixel pop basically just went dead so double checked all wiring again connected 2nd pop and same thing no lights then it went dead
  6. #206
    Nov 2018
    Houston, Texas
    1,383
    Default Re: Rbl ?
  7. #207
    6,368
    Default Re: Rbl ?
    Did the unclipped wires on the end short ?
    Have you managed to get these to light up at all ?
    Also , why is the red and white split like that ?
    I would setup a test with the 5 pixels(15 leds) and get them working.
  8. #208
    Nov 2018
    Houston, Texas
    1,383
    Default Re: Rbl ?
    I think they did on the first one at some point so I clipped them before connecting the second one .
  9. #209
    6,368
    Default Re: Rbl ?
    If they shorted , you may have killed all that were connected
  10. #210
    6,368
    Default Re: Rbl ?
    Do a very simple safe test with 1 single pixel(3 leds) brand new - not used.
    no unclipped ends !
